Dear All
One of my customer site wonts to install Co CPU for use VOIP -1 bords
The Version is 5.1
Importent: Prasently my co cpu is not working, so i put 5.1 extracted file on lola mode ,After that i selected the dip switch CO CPU mode
But i tried so many times CO CPU not configer the cabiner ( Hardwear>main Cabinat>bords)
Please explane me How to config Co-Cpu board
Best Regards,
Shirantha
How to manage CO - CPU -1 OR CO-CPU -2
Re: How to manage CO - CPU -1 OR CO-CPU -2
Hi shirantha
What is the system? OXO or OXE?
Best regards
Best regards
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
- tot3nkopf
enio.eltz wrote:Hi shirantha
Best regards
CoCPU is only used on OXO.
Hi shirantha,
You don't need to use LoLa with CoCPU. Simply manage IP address of CoCPU (VoIP master or slave) in Hardware and Limits/ LAN/IP configuration. ANd interconnect your CPU to Ethernet switch and your CoCPU to the switch and wait about 15-20 minutes for first start of CoCPU.
May be, participation in training courses of OXO would be helpful for You.
Thanks to all for reply my answer
my pabx is oxo ......
I will do last answer procedure & reply your,s
Again thanks to all,
Best regards
Shirantha
Best regards
Shirantha
Dear All,
My CO CPU problam is solved
thanks to all for help me ......
Shirantha
Shirantha
