Problem with international calls
pittas
Post by pittas »
Help! I have the following issue when trying to call international to Canada.
After dialing the last digit of the number (13 digits including the 00 for international), I get 'Replace Handset' on the display of my phone and the line closes.
In 'Translator-->External Dialing Plan-->Dialing (Numbering) Discriminator-->0 public-->Discriminator rule' I have the below settings:
Call Number: 00
Dialing area: 7
ARS Route List Number: 1
Schedule Number: -1
Number of Digits: 14
I have tried changing the number of digits to 13 to exactly match the numer of digits for the number but this does not make any difference.
Any help is appreciated.
thanks
Us I understand you use ARS (ARS route list number 1 in you case) - may be you have problem with ARS routes?
pittas
Post by pittas »
hey, thanks for your reply vad. It seems I made a typo error!
Actually my ARS is set to 0 not 1 as I said previously.
A strange thing that I have noticed is that the call has managed to get through some times. I have got the team from our switch side to also take a look on their part
oldboy
Post by oldboy »
Try using direct trunk seize and see if that works better....???What does the T3 indicate
Try simulating with:
lookars i
Use a prefix for PROFESSIONAL TRUNK SEIZURE , and try to call it to see if you still have the trouble..
phengvanna
Post by phengvanna »
Did you had configured any ARS if Yes
- Which trunk group that cal will rout to
- Then in that trunk group make sure
Number of digit to send has set to appropriated (Ex 13)
Try to use Proffessional TG with overlapping
Note: calling number 00, ARS rout list number 0 where it rout to
Please check ARS rout list 0, ARS rout 1
Return to “Translator”
