PS3 OXO
johar.mohammed_DUP
PS3 OXO
Post by johar.mohammed_DUP »
Dear All,
Thanks in advance,
Please suggest me when i am conecting external battery 3*12 volt,7Ah with PS3N with CPUe-2 then external or internal battery are not working i.e not giving backup.
But when i am connecting normal CPU-4 or CPU-3m or CPU-2 then external battery power backup are working for approx 20 min.
Please suggest me if any one face this problem
Thanks a lot
Johar
et
Re: PS3 OXO
Post by et »
It's strange. May be faulty CPUe-2?
mavijitr_DUP
Re: PS3 OXO
Post by mavijitr_DUP »
Normally, CPU has four connectors but the CPUe-2 has five connectors.
check you motherboard for the number of connectors.
if it has five connectors then check is there any damage in the pins.
Return to “Hardware”
