hotmenu problems with Release 8.0.1 - g150317d
gianluca.antoniutti
Post by gianluca.antoniutti »
Hi everybody,
after migration from R3.1 to R.8.0.1 the hotmenu don't permit to put in check in or check out the single guest room. I cannot write the number of the room
I can put in check in or check out the groups.
If I check the status of busy room in the system I cannot look the number of each cabin but only the total number.
Please help me.
whistler_DUP
Re: hotmenu problems with Release 8.0.1 - g150317d
Post by whistler_DUP »
probably, its translation of database problem. did you save database r3.1 with "fichges" tool ? sometimes it is better to do migration in several steps: in lab first translate DB to r5, and after what to r8... anyway, tool @hotdebug@ and hotel menu works in r8 in room and guest mode on several hotels, what i have manage to set up.
Gedeon
Post by Gedeon »
Probably bad state in database for the sets used by room.
You can restore R3.1 database in labs, check out the sets, and translate, then check in the clients.
G.
try to check out manually all the rooms in both PMS and PCX and then try again.
Return to “Hotel / Hospital”
