call disconnection
call disconnection
there is any way to timebased automatic call disconnection in OXO?
Re: call disconnection
there are two different public numbering plan in the OXO (Normal and restricted), and U can manage the time base routing in the Time Ranges menu.
If this isn't enough for you, use the incoming ARS feature. Because in the ARS U can create more than 2 Time ranges. (but this is so complicated...)
- Krusty65
There is its called OutGoing Call Duration (OCD) but it is only available in China
K.
K.
- tot3nkopf
Hmm didn't knew this feature exists. But why activated only for some markets?Krusty65 wrote:There is its called OutGoing Call Duration (OCD) but it is only available in China
K.
It would be a great feature for us, too.
On R7.1 there is OCD feature but it published on April 2009 (Hope)..
