Hi all,
I'm asked by my customer to install MM32P (On hold music daughter board)
I tried installing it on the AC-1 card and configure it accordingly as below:-
1) On Hold Music - select Music Daughter Board
2) Restart system
3) Auxillary Interface - Start/stop music (options white out, can't be changed)
Tried swapping CPU, MM32P, AC-1 still not working.
May I know what gone wrong in my on-hold music setup ? Is it something to do with my settings ?
Please help me as this problem has been dragged on for long time.
On-Hold Music Problem
Re: On-Hold Music Problem
First, you need to record Music to MM32P, after installing it on AC. You can record from 4035/ 4034 type set.
Do you mean the daughter board doesn't come with the built-in music ? or comes with any default music ?
And how do I record into it ?
Any steps or guides for it ? My office had already discarded the manuals for this particular model. So I don't have any documentation to refer to and it makes my job hard.
Try this: from the 4035 set: System-> Install -> (Password) -> Voice -> MUSSRC -> Voipr.
Okay, I tried that settings and it worked. I'm able to record the music through the phone.
But how do I turn it on from programming to enable the on-hold music ?
Okay, the music has been recorded and turned on.
But I tried using external source MOH but nothing happened.
Anyone can advice me in this matter ? I'm still stucked with this matter. The documentation didn't state much on the cable connections on the MM32P pinnings.
file from document:
