I have a problem with an CPUe-1 (Intel). First I tried to boot it up and change configuration with OMC
but I always had a http error when using the standard IP for logging in (192.168.92.246). It worked with every other CPU so I was off the opinion that this happens because the previous owner changed the CPUs IP adress (used equipment). I searched the forum then and found the solution of removing the CPUs battery for a short while which has the same effect as a cold reset and should switch the IP back to the standard one.
But now the CPU does not boot at all. After powering up CPU LED blinks for a while and then lights permenantly.
Has anybody an idea why the CPU is not working properly and how to solve this? Would be greatly appreciated
Thanks in advance!
best regards
Alexander
