MIX448-2 not coming up
tdev12
Post by tdev12 »
I have a small Media Gateway driven by GD-3. CS runs R101.0-n3.521-8-a-k2-c0s1.
No matter which slot I put it in, my MIX4/4/8-2 card does not come up, it stays "REG NOT INIT". No error message is displayed in incvisu.
Crystal 2 : (PSID : 2) (External Power Supply)
| 2 | 0 | GD3|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 1 | PRA T2|---------- | IN SERVICE | BAD PCMS CODE |
| 2 | 2 | MIX448|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 9 | BRA 4|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 10 | UAI 4|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 11 | SLI 8 (Z)|---------- | REG NOT INIT | BAD PCMS CODE |
| 2 | 27 | GPA FICTIF|---------- | IN SERVICE | BAD PCMS CODE |
I tested the card in OXO and it works fine. Do you have any clue?
Thanks!
Solandsystel
Re: MIX448-2 not coming up
Post by Solandsystel »
Are you sure your Mix card is OXE compatible?
Return to “Media Gateway”
