Faulty key in attendant console
alexandros_z
Post by alexandros_z »
Hi all,
I have an OXE R 12.1 already installed in a hotel. I have one attendant set PAC 2 equipts, but the "transfer" key is not working. I am looking for a workaround and would like to know if it is possible to configure another key (e.g., F12) as a transfer key. The problematic "transfer" key is in the bottom right corner.
Thank you in advance,
Alex
oldboy
Re: Faulty key in attendant console
Post by oldboy »
Yep just go into Attenedat set and key programmign and program whatever key you want, there are a few transfer options
alexandros_z
Dear Oldboy,
Thank you for your response. I had already attempted this before I sent this thread, but I think I did not find the proper configuration that I need. Do you think that the following parameters could potentially solve the issue?:
Prefix Meaning + Data Transfer,
Data Transfer + Connect
Do you have any other suggestions?
Alex
Return to “Attendant”
