OXE CPU 7-2 not rebooting most of the time
morio
Post by morio »
Hi experts,
got a strange issue now. the cpu works and boots very rarely but most of the times it will hand at
check lock RTC
unlock RTC forced
IO2 absent
it floppy received
FDTest= 660740
value of DIL switch forced CPU7 2 << this point. regardless i switch on maually or just shut down the shefl it hangs here. some times when it does boot properly, and i log in and give the reboot command it halts and never reboots by it self. needs to off the switch and on again.
i have 3 cpus with same isue. have changed the rams. and by the way this issue come even with or with out the hard disk. im 100% sure its not the hard disk and the ram..
Any hints guys..
VVVbelow is a complete trace capture sduring a reboot and stops... VVV
1Mo RAM OK
hub = ICH2
loading XILINX
first address: FFF50000 ,last adress: FFF729F4, first value : FF
binary size : 138 Ko (141812 octets)
FPGA HEX download begin
FPGA download finished
CheckSum = 0x65
Configuration ended (DONE = 1)
No error (INIT/ERROR = 1)
SR7= 0
Memory Test
cascaded counter RESET and Watchdog restarted with 255 min
running flash(soldered=1 socket=0)=1,BIOScase:4,BIOSv24:0,verrou=1,algoNOR=1,size=4,base=FFE00000
Bios case 4
*** CPU7-2 Board version 3BA23259ABJE04�� ***
*** CPU7-2 Layout 1 ***
*** BIOS Version 3BA24115AAFC bscpu7300/004.003 ***
*** Generated on Mar 23 2015 at 19:11:52 ***
*** Celeron @ 648 ***
CMOS is available
PCI command read for natsemi : 347
PCI Master Bit Setting...
pci_command set to: 357
0:80:9F:73:8F:8B
73 , IRQ 12.
eth0: Transceiver status 0x 7869 advertising 5E1
Hard Disk #0 : HGST HTE545032A7E380 131071 Mo
Parameters :
Type 3
Extended Type 255
Sectors / track 63
Landing Zone 0
Control Byte 0
Write Precomp 0
Heads 16
Nb of Cylinders 16383
HD size(cyl*sec by track*head*sector size) 8455 MO(decimal)
time :sec= 0,min=10,hour=11,DoW= 0,date= 0,Month= 1,year= 4
RTC not valid
time :sec= 0,min= 0,hour= 0,DoW= 7,date= 1,Month= 1,year= 0
time :sec= 5,min= 0,hour= 0,DoW= 7,date= 1,Month= 1,year= 0
cmos ram not valid
CPU7 informations :
Memory Detected : 262144 Ko
Flash Not Detected
DaughterBoard Not Detected
XILINX Detected
XILINX Chip Initialization OK
Ethernet Found : 1
Ethernet Chip Initialization OK
Hard Disk Detected
Hard Disk Found : 1
check lock RTC
unlock RTC forced
IO2 absent
it floppy received
FDTest= 660740
Re: OXE CPU 7-2 not rebooting most of the time
issue with IO2 , have you io2 with your cpu
check the autostart
try to start tel appli it without io2
>RUNETL -DNOIO2
morio
Post by morio »
Hi Haroun,
Thanks for the reply. The issue happens even with out the hard disk. The issue arises befor the bios boot set up. so it has nothing to do with MAO / AUTOSTART or any other. this happens at the early stages of the booting process of the CPU.
Return to “Shelf”
