Hello.
I'm trying to create a policy that only allow certain mac-adresse on a specific port of the switch.
policy mac group cdcl-1 xx:xx:xx:xx:xx:xx aa:bb:cc:dd:ee
policy condition cond_cdcl-1 source port 1/1/10 source mac group cdcl-1 destination ip Any
policy action act_accept disposition accept
policy rule ru_cdcl-1 condition cond_cdcl-1 action act_accept
qos apply
But curently I wasn't able to get something running...
I miss something to get a "implicit deny" for the other mac adress..
could you help me out ?
Thank's in advance !
policy and mac group
Re: policy and mac group
Hi!
While you can certainly do this with a Policy, have you considered simply using Port-security instead? Unless there's a bigger configuration objective you are not mentioning, this seems like a good use for it. Something like:
You can even have 8 ranges per port as well!
port-security port 1/1/10 admin-state enable
port-security port 1/1/10 mac-range low 01:23:45:00:00:00 high 01:23:45:ff:ff:ff
Hello cristek.
I need to allow 6 differents mac adresses wich are not from the same vendor, so, not in the same range
EDIT : my bad, I haven't read the "8 range" part
I'll try that, thanks !
Something like this?
port-security port 1/1/1 maximum 6
port-security port 1/1/1 mac aa:aa:aa:11:11:11
port-security port 1/1/1 mac bb:bb:bb:11:11:12
port-security port 1/1/1 mac cc:cc:cc:11:11:13
port-security port 1/1/1 mac dd:dd:dd:11:11:14
port-security port 1/1/1 mac ee:ee:ee:11:11:15
port-security port 1/1/1 mac ff:ff:ff:11:11:16
So, I've just tried it.
It work, but notas intended. :-/
With that, these 6 mac adresses will automatically get the default port vlan.
I use an unp profile on the switch, my default vlan is a "blocking vlan".
So, Yes, I have a bigger configuration objective i'm not mentioning... Sorry.
You can add a vlan to it:
port-security port 1/1/1 mac cc:cc:cc:11:11:13 vlan 123
I saw that, but it only allow the default vlan.
But this seems to do the trick :
policy mac group cdcl-1 AA:bb:CC:dd:EE:FF
policy condition cond_allow_cdcl-1 source port 1/1/10 source mac group cdcl-1
policy condition cond_drop_no_cdcl-1 source port 1/1/10
policy action act_drop disposition drop
policy rule ru_accept_cdcl-1 condition cond_allow_cdcl-1 action act_accept
policy rule ru_drop_no_cdcl-1 condition cond_drop_no_cdcl-1 action act_drop
qos apply
