Both power supplies on the 7210 SAS-MXP are indicated as not equipped.
filipgermenji
Post by filipgermenji »
Hello
I'm encountering an unusual situation with the 7210 SAS-MXP power supply. This switch has two power supplies: one AC 220V and one DC. Both power supplies are showing as "not equipped," yet the switch is operating normally.
The same issue occurs even when change position of PS, even if i replace the PS with one from another switch.
# show chassis power-supply
Chassis Information
Power Supply Information
Number of power supplies : 2
Power supply number : 1
Configured power supply type : ac single
Status : not equipped
Power supply number : 2
Configured power supply type : dc (-48V)
Input power : out of range
Output power : out of range
# show system alarms
Alarms [Critical:0 Major:2 Minor:0 Warning:0 Total:2]
Index Date/Time Severity Alarm Resource
Details
1298 2024/08/25 13:33:52.30 MAJOR 7-2011-1 Power Supply 1
Power supply 1, power lost
442 2024/08/19 05:09:44.30 MAJOR 7-2011-1 Power Supply 2
Power supply 2, power lost
# show version
TiMOS-B-20.9.R5 both/hops Nokia SAS-Mxp 22F2C 4SFP+ 7210 Copyright (c) 2000-2021 Nokia.
All rights reserved. All use subject to applicable license agreements.
Built on Wed Aug 25 12:46:54 IST 2021 by sasbuild in /home/sasbuild/20.9B1/R5/panos/main
# show chassis
Type : 7210 SAS-Mxp 22F2C 4SFP+-1
Part number : 3HE10075ABRB01
Has anyone else encountered this situation, and what are recommendations for this issue?
Return to “7210 SAS”
