How to initiate IC 8082?
Bakala
Re: How to initiate IC 8082?
Post by Bakala »
Hello, something happened that from yesterday to today my account was deleted and I had to create it again. I have the 8082 connected directly to the router via Ethernet. And about having to set up a server, is it necessary to have any mandatory program? All the best
Well.. Where do you want to connect your phone to if you don't have anything to connect to..? :)
Bakala
Post by Bakala »
Ok, I deduce that it must necessarily be connected to a PC. So there it will be necessary to buy and install the OmniVista 8770 program that I have been able to read in the manual, is this correct?
I really appreciate your help; I also don't want to be bothersome by asking too many questions, so once I know the main thing that is needed, I will try to find out the rest on my own.
You need more than a PC. You need an entire phone application... 8770 is only a management software.
Return to “My IC Phone”
