SNMP on VRF ip interface
DrsM
Post by DrsM »
I was setting up an SNMP v2 sensor (uptime) from my monitoring server to an ip interface address on a VRF couldn't get it working.
Show snmp statistics gives alot of snmpInBadCommunityNames packets.
When I use an IP interface address on the default router it is working like expected.
Can someone help me understand why snmp to a vrf ip interface isn't working?
Thanks in advance!
Re: SNMP on VRF ip interface
you need to activate all special services per vrf. Check within the vrf "show ip service"
best regards
DrsM
Post by DrsM »
This did the trick, thanks alot!
Return to “OmniSwitch 6900”
