swlogd VlanMgrNi main INFO: VM-NI-VPA-EVENT>vmUpdateVpaState@3724-> ifIndex=40000005 vid=1188 vpaState=1 remote:0 gen ev
rtabor
Post by rtabor »
This log starting appearing in very large numbers.
swlogd VlanMgrNi main INFO: vmUpdateVpaState@3722-->Not updating the Vpa state as the link is down
swlogd VlanMgrNi main INFO: VM-NI-VPA-EVENT>vmUpdateVpaState@3724-> ifIndex=40000005 vid=1188 vpaState=1 remote:0 gen evt:1
Re: swlogd VlanMgrNi main INFO: VM-NI-VPA-EVENT>vmUpdateVpaState@3724-> ifIndex=40000005 vid=1188 vpaState=1 remote:0 ge
not sure about that all. But I think ifIndex=400000 means Linkagg 5 (or 4 - you have to check). VID is the vlan id. Do you see any issues in your network?
check this linkagg - especially the vlan 1188 at both sites.
best regards
Return to “OmniSwitch 6900”
