block incoming call to alcatel lucent omnipcx enterprise
Tonydo6789
Post by Tonydo6789 »
hi bros,
could you please help me to guide me the how to configure how to block incoming call from outside to ext or all pcx ?
example : 1234567 is incoming call .
ext1 : 1111
ext2 : 2222
i had looked on internet and saw that i need to configure translator/called filtered number and abbreviated numbering .
but i still cannot success because i never do it before and no have the template and documents.
if bros have any documents and guideline pls kindly share for me.
I really thanks so much.
my email : hoaithanhdo@gmail.com
Regards !
Re: block incoming call to alcatel lucent omnipcx enterprise
I was thinking about developing an app to block incoming calls very easily.
Anyone would be interested ?
alex
Post by alex »
Hello Frank
I think a lot of people would be interested but where this app would run?
It would be a box in between your carrier and oxe...
sadim
Post by sadim »
Please check the feature Call Filtering Routing.
Also in this site there are also some examples.
@sadim
What doc is this in?
I searched for filtered called and call filtering in the doc, but nothing came up.
Do you have a doc number?
sadim
Post by sadim »
Hi Frank,
This feature is on the system doc/General Applications.
For example for R12.4 the file is: oxe12.4_sd_GeneralApplicat_8AL91010USAI_2_en.pdf
Check the chapter 13 - Caller/Called Filtering
here is the file for anyone who needs the doc about it.
What a pain I the butt to setup. Frankly :/
alexeik
Post by alexeik »
yeah, and not usable if you need to block an number completely...
what, this doc? Why is that?
Never done it frankly, I setup another home made solution.. :/
Return to “Translator”
