Port Security 2 Mac-Address
marcologrado
Post by marcologrado »
Can I do a port security in my Alcatel 6450 in a port winth 2 equipments, one voip and one PC, with differnts vlans.
Exemple:
show mac-address-table 1/2
Legend: Mac Address: * = address not valid
Vlan Mac Address Type Protocol Operation Interface
4 00:80:9f:e3:b4:75 learned --- bridging 1/2
110 00:80:9f:e3:b4:75 learned --- bridging 1/2
Total number of Valid MAC addresses above = 2
The switch give me the same mac-address..
Marco Logrado
Re: Port Security 2 Mac-Address
If 802.1x is activated at the phone and the phone is 802.1x-tagging in voice vlan, than the eap-packets will always sent untagged and the voip packet are tagged. So the phone is in this case in both vlans and also twice in the mac table. You can disable 802.1x at the phone or allow at least 3 mac addresses in port security.
best regards
marcologrado
@silvio Thank you very much. I'm gona try...
Return to “OmniSwitch 6450”
