OV2500NSM 4.3R1
sirmanhhung
OV2500NSM 4.3R1
Post by sirmanhhung »
Hi guys,
Could you tell me how to check the Client Sesssion Logging Image
Thank you
Re: OV2500NSM 4.3R1
where did you see this image? I have never seen it. Are you connected as admin?
I only know "Administration > Control Panel > Session Management" for active sessions.
All the logs you find via "Administration > Audit"
sirmanhhung
Re: OV2500NSM 4.3R1
@ Silvio: I see it on Access role Profile, it is a new feature on 4.3R1Image
Client Session Logging
• Client Session Logging - Enables/Disables online/offline/roaming client session
logging.
• Client Connection Logging Level - Select a logging level:
• Logging HTTP/HTTPs - Log only the HTTP/HTTPs web session of wireless
clients.
• Logging ALL - Log all sessions of wireless clients, including HTTP/HTTPs.
• None - Log only client online/offline/roaming behavior, without session
details.
I want to check the log of client connection but i do not know how
I connected at admin.
Re: OV2500NSM 4.3R1
now I have found your point. Now I am remote connected to OV without wlan clients.
But I have two ideas where to find the log: normaly you do you config via template.... but for some specific points it's good to look into device config...
not sure. But you can try to find there more. Maybe within the reports.
Or in the administartor > audit section. Very complicate to find something there.
Please open a ticket at alcatel if you can't find it by yourself and share your results with us.
thanks
sirmanhhung
Re: OV2500NSM 4.3R1
Hi Silvio,
I am still waiting update from alcatel support but i find this feature can operate on express mode, we can see information about connection status
http://www.upsieutoc.com/image/47x6JA
Re: OV2500NSM 4.3R1
Now I have searched in OV too for this logging. But without any success. I am interesting in the answer from alcatel :)
ymilner
Re: OV2500NSM 4.3R1
Post by ymilner »
Did you try syslog under audit / system?
Sent from my SM-G965F using Tapatalk
sirmanhhung
Re: OV2500NSM 4.3R1
Hi guys,
New infor, The log has storaged at Stellar AP, we must use tftp server for uploading it.
Follow the pic, my tftp server ip add : 192.168.10.123
Now we can find the remote path and the log file will be uploaded at here.
Re: OV2500NSM 4.3R1
Thanks for sharing this information. I hope that in next release of OV this infos will be visible direct in OV too.
