Unable to use Java applets remotely
jlambwac
Post by jlambwac »
Hello Everyone.
I am testing OmniVista 2500 NMS 4.1.2.R03 and am having some difficulty loading the java applets on remote computers. I have been able to successfully have the web interface load and have the java applets connect to the server but when they go to load this error occurs: "Login Failed on Server 'X.X.X.X' port 1127. Cant Connect to server at 'X.X.X.X:1127'. Can't connect to X.X.X.X.
Obviously there is a connection made since I can get to the web interface but I am sure I am missing something that needs to be allowed on the server firewall I just don't know what. If I disable the server firewall it works just fine. Server is Windows 2012. On the local server everything is working normally with the applets.
Any ideas will be appreciated.
Re: Unable to use Java applets remotely
maybe you have forgot in the system settings of the client to make the entry for the OV server (java - security - sitelist).
In OV4.2. you don't need java anymore. Better you do the update to this release :)
jlambwac
Post by jlambwac »
So I decided to scrap getting 4.1.2 to work. Now testing 4.2.1 and while I had a momentary issue where it wouldn't find anything, that has been resolved and everything is working fine.
