unable to access the voice mail
HUSSAINQCS
Re: unable to access the voice mail
Post by HUSSAINQCS »
I can understand the doc but the issue the voice mail is not able to delete for some extensions only after do the check in in hot-menu it works again but i have configured the voicemail for all the extension without doing check in
Will i need to do check in for every voice mail allocation ?
HUSSAINQCS
06/07/17 10:19:11 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.16 Module 0x 0. 0 Line 0x 0.54
06/07/17 10:21:26 000001M|000/10/-/---|=5:2059=St-by CPU put in service
06/07/17 10:21:38 000001M|018/01/-/---|=4:5400=4645 Software Error: Error Code 0x 0.16 Module 0x 0. 0 Line 0x 0.54
06/07/17 10:23:49 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
06/07/17 10:33:58 000001M|---/--/-/---|=0:1612=Protocol error on Alcatel 8&9 series, type 13 (neqt 2229)
06/07/17 10:33:58 000001M|---/--/-/---|=3:1613=15.04.0d.00.02.02.8b.29.00.ff.00.00.00.00.00
06/07/17 10:50:08 000001M|---/--/-/---|=3:1125=external alarm : "mtcl login"
HUSSAINQCS
I was getting the message in the incidents and for some users voice mail announcement is saying unknown mail box number
HUSSAINQCS wrote: 06 Jul 2017 04:51 I can understand the doc but the issue the voice mail is not able to delete for some extensions only after do the check in in hot-menu it works again but i have configured the voicemail for all the extension without doing check in
1 - please read documentation - exist some specific management for VM (and for VM in Hotel environment - store VM until next check-in or not, allowed to delete mail box with messages or not, etc.)
2 - if you need help - explain your management (what managed in System and Application - for VM and Hotel).
3 - "but i have configured the voicemail for all the extension without doing check in " - see p.2, without your management explanation - how we can give you some answer? All extension - you say about administrative user (or room, or guest)? Etc...
HUSSAINQCS
Thanks Mr.Vad for support,
This is happening for room extension
HUSSAINQCS
I have already created the voice mail for those users having problem but still when i try to access the voice mail box it was saying "unknown mail box number"
This is happening for some extension and for some extension still i can able to reach voice mail box
HUSSAINQCS
Earlier i have created the voice mail for all the room users without doing check in hot menu but now once you done check in hotmenu then only it is saying "you have reached the mail box of .."
HUSSAINQCS
Can anybody explain why i getting the incident 5400 in OXE ?
Return to “Application”
