How to external contacts in omnivisita 4760
moelhawa
Post by moelhawa »
Dears
I need to add some frequently dialed external numbers in omnivisita 4760
And these contacts will appeare in calls reports with their names
I think it is in accounting window of OV4760, but I forgot how to add contacts, this like as making an address book in the OV.
thanks for your help
Re: How to external contacts in omnivisita 4760
Abbreviated Number?
moelhawa
Post by moelhawa »
No, it is like a address book inside the OMV containing frequently dialed numbers.
i.e I can save in OMV mobile # 123456789 for person named moelhawa for example.
then when this mobile number dialed from any extension in the PABX, the OMV matches dialed number with the saved numbers inside its DB (address book), then we can filter more easily as the name moelhawa will appear in the calls report.
thanks for your help and reply cavagnaro
Ohhh guess I got out dated on Omnivista
moelhawa
Post by moelhawa »
ok, thanks for the reply, but if there is any one remember this issue, it would be better.
thanks for any help.
swinstu
Post by swinstu »
Dont think you can filter out names for speeddial numbers in reporting however you can filter called number in your reporting in OV4760.
Sent from my SM-G920I using Tapatalk
SWINSTU
ACSE OXE R12.1
ACSE 8770 R3.2(4760 R5.x)
ACSE OT R2.3 IP/SIP and UC&C
moelhawa
Post by moelhawa »
Unfortunately it was working and it differs than filtering process during generating a report.
This option is exist (creating a phone book inside the OMV)
The second point is I'm trying to restore an old backup to solve this issue and to solve another issue in cost calculations but it always failed, whoever all server parameters are configured correctly ( server name, DNS Suffix,.....)
Thanks to for your reply all
If I success to restore old backup it will be great.
edwintufis
Post by edwintufis »
Hi friends, i dont know if this is the right place to ask this, I have a Appliance OXE, but my omnivista is in win 2003, and because of internal laws of my company they dont want any server in win 2003, but the upgrade of appliance and server is like 40000$, we dont have that money, i want to know if there is a way to connect directly to the appliance via serial port, or any other way with other address ip the omnivista and the appliance so they only see each other, and the program that the company use dont scan the omnivista. thanks hope you understand me.
Return to “OmniVista 4760”
