External Callback translator issue
taahir10
Post by taahir10 »
We are having an issue at a customer place after the creation of the default external callback rule. The trunk group name was displayed before the creation on the rule instead of the calling number.
After setting up the DEF rule they are now able to see the number but "Express" is also being displayed before the number (see attachment). the DEF was configured as follows.
x Instance (reserved) : 1 x
x External Callback Table : 0 x
x Basic Number : DEF x
x x
x Nb.Digits To Be Removed : 0 x
x Digits To Add : 0
The PABX version is R11.2.1 L2.300.29b
alexeik
Re: External Callback translator issue
Post by alexeik »
I Bet you have a Speedial with the Name "Express" and callnumber 0. So the Callnumber will change in every call.
Return to “Translator”
