Elastix and 4018 sets issue
Soft_Master
Post by Soft_Master »
Hi Gys,
I've some 4018 sets and I want to use them with elastix box, I did all the necessary configuration, the problem is : the sets download the flash and configuration from the TFTP server, register to the elastix and work good then after a while the registration is lost and I get this log:
000-18:00:06.110 CH : sip-tls : get SIP_TRANSPORT_MODE_SURVI failed!
000-18:00:06.110 DISPLAY: ui_setprop(13):not created!
000-18:00:06.110 DISPLAY: ui_setprop(15):not created!
000-18:00:06.110 DISPLAY: ui_getprop(15):not created!
000-18:00:06.110 DISPLAY: ui_getprop(16):not created!
000-18:00:06.110 DISPLAY: ui_object_setprop(0x80d69580):no this property!
000-18:00:06.110 DISPLAY: ui_setprop(14):not created!
000-18:00:06.110 DISPLAY: ui_setprop(16):not created!
000-18:00:06.120 DISPLAY: ui_setprop(16):not created!
000-18:00:06.120 DISPLAY: ui_getprop(15):not created!
000-18:00:06.120 DISPLAY: ui_getprop(16):not created!
000-18:00:06.120 DISPLAY: ui_object_setprop(0x80d69580):no this property!
000-18:00:06.150 DISPLAY: ui_setprop(13):not created!
000-18:00:06.150 DISPLAY: ui_setprop(15):not created!
000-18:00:06.150 DISPLAY: ui_getprop(15):not created!
000-18:00:06.150 DISPLAY: ui_getprop(16):not created!
000-18:00:06.150 DISPLAY: ui_object_setprop(0x80d69580):no this property!
000-18:00:06.150 DISPLAY: ui_setprop(14):not created!
000-18:00:06.150 DISPLAY: ui_setprop(16):not created!
Please Help
Thnks
ahmedfahmey
Re: Elastix and 4018 sets issue
Post by ahmedfahmey »
i have the same issue right now, did you found any solution ?
This is an issue on sip server side now, we can't help on that side
