Voice mail = network congestion
Recoil
Post by Recoil »
Hello People,
When users press the envelope on the 8068 handsets and press "voice mail" or on "1 new voice message" Network Congestion is displayed.
How do i fix this one?
L_lefante
Re: Voice mail = network congestion
Post by L_lefante »
Can you call to voice mail directory number or do you have same result?
Was this working before?
Check the status of voice mail. Particulary lines via Eva_tool
Recoil
Post by Recoil »
Hi L,
Thanks for responding.
Voice mail was working before.
When I ring the voice mail no: it says: voice mail unobtainable.
Checked status of lines via Eva_tool all OK.
Your choice :8
nulog Free/Busy stat
0 F OK
1 F OK
2 F OK
3 F OK
4 F OK
5 F OK
6 F OK
7 F OK
8 F OK
9 F OK
10 F OK
11 F OK
12 F OK
13 F OK
14 F OK
15 F OK
16 F OK
17 F OK
18 F OK
19 F OK
20 F OK
21 F OK
22 F OK
23 F OK
24 F OK
25 F OK
26 F OK
27 F OK
28 F OK
29 F OK
Recoil
Post by Recoil »
I had techs close coupler & reboot the virtual vmail shelf with no luck, they then rebooted the OXe with still no success.
one full day after the reboot voice mail returned on its own.
One for the X-files but thanks for your assistance.
Check dsp recourses - compvisu lio, config all.
As I remember you need 8 dsp channel for VM.
