checkSystemLinux.sh
hassansalem
checkSystemLinux.sh
Post by hassansalem »
Thanks in advance
we are in need for your valuable support for the below mentioned issue :-
We did the following :-
1- RHEL 6.5 installed on our server
2- We already accessed the GUI mode under root account
3- We already mounted the messaging software DVD and get accessed
4- We started to install the messaging software by checking hardware compatibility (path : /media /cd rom / ) via command checkSystemLinux.sh
5- After we issued the above command , we got the error : this server is not installed with an UC/ICS/NGVM – Compliant update of RHEL 5 [failed]
Please advise , How we can solve this problem ?
Re: checkSystemLinux.sh
6.5 is not supported as far as I know, only 5. Check system compatibility
hassansalem
Thanks Cavagnaro for valuable support ,
1-I installed RHEL 5.8
2- I started to install the messaging software by checking hardware compatibility (path : /media /cd rom / ) via command checkSystemLinux.sh
3- After we issued the above command , we got the error : Checking SELINUX is disabled ,
SELinux is not disabled in /etc/Selinux/ , Do you want to fix it ?
Please advise.
tgn
Post by tgn »
have you installed the rhel with the alcatel boot dvd infront?
regards?
Please...please... Please...at least read the instructions on the installation guide. You are doing this by following your instincts? That definitely will not work
Return to “OmniTouch 8440 Messaging Software”
