Auto Attendant
AlphaTechSec
Auto Attendant
Post by AlphaTechSec »
Hi All
Can anyone please tell me how I add a recording to the Auto Attendant?
I have found where to input the recoding on the system but not sure what format and so on it needs to be recorded at and is there some software best for doing so?
Thanks Dan
L_lefante
Re: Auto Attendant
Post by L_lefante »
The audio file characteristics are:
Wav, 16 bit, mono, 8 kHz.
You can upload it from OMC >> Voice Processing >> Automated Attendant.
AlphaTechSec
Re: Auto Attendant
Thanks L_lefante worked fab.
AlphaTechSec
Re: Auto Attendant
I can I also ask if there is a Max time length for the recordings?
i'm asking as I want to change it on another system and its not working but wasn't sure is it was don't to the time length?
the new recording I want to use is currently 17sec long.
L_lefante
Re: Auto Attendant
Post by L_lefante »
I dont remember the exact max length for the recording but I am sure that you should not have any problems with 17sec.
What is the particualar error you are getting?
AlphaTechSec
Re: Auto Attendant
Hi L_lefante
the message I get is THE VOICE PROMPT TRANSFER FAILED DUE TO EITHER TOO LONG FILE SIZE OR INSUFFICIENT ACCESS RIGHTS.
I have tried to upload the same files to another system we have and that works fine.
thanks Dan
PlanoPCX
Re: Auto Attendant
Post by PlanoPCX »
You can also record through the handset, as long as you use one of the models with a larger screen (8038/39/68, 4038/39/68)
L_lefante
Re: Auto Attendant
Post by L_lefante »
AlphaTechSec wrote:Hi L_lefante
thanks Dan
What CPU do you have? PowerCPU or CPU-4?
morgante
Re: Auto Attendant
Post by morgante »
Se for operadora automática, precisa de licença. Normalmente é permitido a gravação de 04 mensagens. Verifique se não ha outras mensagens gravadas
Re: Auto Attendant
Inglês...
Return to “Beginner's questions about the OmniPCX OFFICE”
