I want to change the number of rings for a specific entity. I know I can change that on System Time 4, but that would be for the entire system. Is there a way to change for the entity or a particular group?
Also, what controls the number of minutes someone is on hold before the ring back?
Charles
Number of Rings per Entity
Re: Number of Rings per Entity
You dont do it by entity it is done by Fac Cat depending on your software release.
- cavagnaro
Just to clarify, oldboy means Facility category.
Enviado de meu C6602 usando Tapatalk
Sorry Cav
- cavagnaro
Hehe you know, not all users have knowledge and English good enough to understand some acronyms
- frank
You can only change the number of rings in release OXE 10+ I think.
Before that, it is one setting, systemwide.
Classes of Service
- Modify your Phone Feature COS #
- Modify - Overflow on Associate/Noreplay Timer -(0 means systemwide)
Users-
- Find your Extension
- Match your Phone Feature COS #
Users-
