depuis le passage en windows 10, impossible de me connecter sur mon oxo en R410 ni avec OMC 700.9.1 (qui fonctionnait tres bien auparavant) ni avec OMC 900.
est ce un pb de réseau,pourtant les adresses IP n'ont pas varié!
oxo et windows 10
Re: oxo et windows 10
cross compatibility,
intercompatibilité , les omc cités cidessus tournent ils sous win10, est ce suporté par alcatel
and nexttime you should post in english , it's a worldwide forum
I recently upgrade my computer from Windows 8.1 to Windows 10 and I can't connect yet to my OmniPCX Office Medium with a CPU-2 Card since the pc'upgrade.
the latest software that I was using in windows 8.1 was : OMC 700 9.1a but it doesn't function with OMC 920 11 1a
Please let me know if there are other information you need in order for me to get this resolved.
- cavagnaro
You already have been answered...Windows 10 is not supported
when was omc supported with win 10 ?
i find more and more windows 10 os and nobody think that it was a good idea to use it ?
- cavagnaro
Ask developers from ALU and MS why API has to change. We are not ALU.
Not everyone supports a new os the day it goes out as its expected to have bugs and not be used on a prd environment
ALE wrote that OMC R10.1/ 24.1a (or above) is compatible with Windows 10. Season greetings !
