SUU in OXO
Pooja Ramchurn
SUU in OXO
Post by Pooja Ramchurn »
In the OXO, I want the SUU enabled. At the level of the extensions, it is already enabled. But still the callee does not receive the calling party number defined in the ARS table.
Can anyone help me out?
Re: SUU in OXO
What is SUU?
Pooja Ramchurn
Re: SUU in OXO
UUS in english...User to User Signaling.
Re: SUU in OXO
you have problems with CLI information from the outside lines or from internal ones. If from outside what kind of lines do you have (ISDN or analog)?
Pooja Ramchurn
Re: SUU in OXO
From the external lines and the lines are ISDN (BRA)
Re: SUU in OXO
You are not able to see calling party on the screen of the digital sets or analog? (if analog try to define them as Z class, if problem on digital sets, too I think it might be a signaling problem from your provider - is your PBX configured for your country?)
Pooja Ramchurn
Re: SUU in OXO
No problem at Provider side. There was previously a 4200 PABX which has been replaced by an OXO PABX R5.1. On the 4200 PABX it was working perfectly well but not on the OXO.
Return to “Configuration”
