OXE Web Services
joao.carlos
OXE Web Services
Post by joao.carlos »
hi,
i really don't know if this is the right place for this question, but was the best association i could do.
I have a customer that hired a software company to develop a system that will connect to OXE.
They've applied to Application Partner Program, and developed the system using the Cloud OXE that they provide.
But now, we have created an test environment on site, and they are asking us to configure the web services on OXE, which they could use on Cloud. Application Partner support tells them it's a BP task to configure it.
Well, as you can see, i have never done that, so, where can i Activate this?
They claim to access the functions using this URL
http://1.2.3.4/AlcApiFrameworkPort?wsdl
or
http://1.2.3.4/api/services/AlcApiFrameworkPort?wsdl
where 1.2.3.4 is the OXE IP Address.
Any help?
Thanks in advance.
joao.carlos
ACSE OXE R12 | ACSE OpenTouch R2 | ACSE OXO Connect R2 | ACSE OmniVista 8770 R3 | ACFE OmniSwitch R6/R7/R8 | ACSE OTCS R8.2
ACPS IP Telephony R12 | ACPS OpenTouch R2 | ACPS Data Networks R6/R7 | ACPS OTCS R8.2
Turlupin
Re: OXE Web Services
Post by Turlupin »
There is no web service directly on Oxe.
You need to use ICS 8410.
Sorry for my english .... :)
All is done via ICS XML API Services.
Licensed of course according to each API usage.
L_lefante
Post by L_lefante »
I am checking API's and in Alcatel Product Page XML APIs are still offered...
http://enterprise.alcatel-lucent.com/?p ... e=overview
However I see that OmniTouch 8419 ICWS is phased out from H1 2104
Does anyone knows if this is stil used?
I think the PRS server is still available on the OpenTouch.
Return to “TSAPI”
