ARS issue - 1st Route SIP TG, 2nd ISDN
Hi all
Ive been tearing my hair out trying to get a "simple" ARS to work using a SIP TG as the first route and then an ISDN as the second.
The reason is pretty obvious, if the SIP TG is out of service/unavailable/un-reacheable/times out, my client wants the calls to route via ISDN.
Ive set these up before with no problems, but Im having real issues with this and can't work out why.
Ive followed every TC and TG I can find in reference to SIP or ARS -
TC0006ed01 - No Operation of ARS
Checked entity 0, but dont think this is appropriate anymore
TC0260ed01 - Overflow Causes on ARS
This more geared on ISDN.. which makes sense since its from 2001
TC1054ed02 - GVP SIP 7.6 connected to ALCATEL OmniPCX4400 with manual components installation.
There are a few timers here that are different in this config example, but there is no difference in the production result
SIP initial time-out 4000
SIP timer T2 8000
SIP connection duration 180000
TRUNK COS31
T306 120
T310 120
T313 120 -> I have tried reducing this to no avail
T314 120
TC1172ed01 - SIP Sets cannot make ARS calls
Not sure if this is applicable, but for SIP registration to work, I did have to create a SIP device. Havent changed values of "Rex Entity to be used in ARS" or "Entity for Og calls to Rex users" yet. They are still FALSE
TC1251ed02 - GVP8.1 / OXE Installation and Configuration Guide
OXE settings and timers are the same as TC1054
TC1820ed01 - Trunking with 3rd Party Guideline
Still working my way through this document.
TG0042ed01 - SIP Troubleshooting Guide
TG0055ed02 - TOOLS AND METHODS TO INVESTIGATE ISSUES OVER IP NETWORK
TG0069ed11 - Session Initiation Protocol Troubleshooting Guide
This is where the notes for SIP registration are
Ive also referred to my ASCE course notes from release 9 (I haven't done then R10 upgrade and my client is running j1.410.40.c.. I know that things like SIP to CH Mapping was introduced.. however Ive tried changing various options in there to no avail either).
I have been testing by dialling an indialable abbreviated number, that then uses an ARS prefix (0) and then dials the number.
To test the ARS failover from Route 1 (SIP TG) to Route 2 (ISDN TG) Ive either changed the Trunk Group setting on the SIP External Gateway to -1 OR Ive added a static route to the SIP Gateway IP address to an invalid destination (ie an IP address that doesnt respond on port 5060).
In either of these scenarios, the inbound ISDN call is rejected by the OXE (or at least recieves a busy tone) and is not passed to Route 2 of the ARS.
Interestingly the motortrace/traced does not show any SIP activity or attempted setup for this call and the T3 for the ISDN shows Unspecified.
| (943543:000004) 1235: Send_IO1 (link-nbr=1, sapi=0, tei=0) :
| long: 22 desti: 0 source: 15 cryst: 2 cpl: 7 us: 8 term: 0 type a5
| tei: 0 <<<< message sent : DISCONNECT [45] Call ref : 80 8d
| IE:[08] CAUSE (l=2) 81 9f -> [9f] NORMAL, UNSPECIFIED
Ive tried various SIP to CH Mapping settings and that hasnt worked either.
The ARS route output is
| A R S R O U T E S L I S T No 2 |
| PIN Code = 0 |
| ROUTES DEFINITIONS |
| 1) trk_grp = 15 dialing_table = 3
| nb_deleted_digits = 0 inserted_digits =
| vpnCostLimit = 0
| idx_atm = -1
| --> trk_grp 15 local TG name : SIP_Local state : PART_FREE
| type : T2 variante : IPNS
| fais_suiv = -1 category = 31 nbjonc = 124
| vpnRate = 50 vpnCostLimit = 0
| ==> dialing_table 3
| command : I
| network : NETWORK2
| SIP gateway : 8
| Route usefull for : SPEECH FAX RESTRICTED AND UNRESTRICTED DIGITAL INFORMATION
| Protocole Type = DEPENDENT ON TG
| Route Type = Public
| NPD Id = 255
| Preempter = 0
| Trunk group source = ROUTE
| 2) trk_grp = 1 dialing_table = 0
| vpnCostLimit = 0
| idx_atm = -1
| --> trk_grp 1 local TG name : ISDN10 state : PART_FREE
| type : T2 variante : ISDN
| fais_suiv = 2 category = 0 nbjonc = 10
| Route Type = Public
| NPD Id = 255
| Preempter = 0
Below Ive noted all the config details that have generally been relevant to this deployment.
Ive tried this using the ABC-F local SIP TG and an ISDN all countries and both of these result in the same call rejection.
If I remove route 1 from the time based route list, then route 2 (ISDN) works perfectly.. Im certain Im missing something simple but I cant find it.
Ive considered that there could be either a bug in the release my client is running that is rejecting this, OR (more likely) there is something to
do with SIP Registration and teh fact Call Handling isnt seeing this GW go out of serivce (or similar) thats causing it to behave this way.
The only other thing I havent tried is using a tuner trace to see all the call processing steps.. I just know know what the tuner options are.
Any help or thoughts would be greatly apprecaited.. as I really dont want to raise an SR if Ive missed something obvious
Thanks in advance, sorry for the giant thread!!
ENTITY 0,1 and 10 all have the same Discriminator Selector settings
┌─Consult/Modify: Discriminator Selector─────────────┐
│ Entity Number : 10 │
│ Instance (reserved) : 1 │
│ Discriminator 00 : 0 │
│ Discriminator 01 : 1 │
│ Discriminator 02 : 2 │
│ Discriminator 03 : 3 │
│ Discriminator 04 : 4 │
│ Discriminator 05 : 5 │
│ Discriminator 06 : 6 │
│ Discriminator 07 : 0 │
All users in Entity 20 have 2 as their PNC.. ARS privilege is
ARS privilege │
│ Night : 31 │
│ Day : 31 │
│ Mode 1 : 31 │
│ Mode 2 : 31 │
│ VPN Cost Limit │
│ Night : 31 │
│ Day : 31 │
│ Mode 1 : 31 │
│ Mode 2 : 31
┌─Consult/Modify: Prefix Plan─────────────────────────────────────────────┐
│ Number : 0 │
│ Prefix Meaning + ARS Prof.Trg Grp Seiz.with overlap │
│ Discriminator Nr. : 0 │
┌─Consult/Modify: Discriminator Rule─────────────────────────────────────────────────────────────────┐
│ Call Number : 0011 │
│ Area Number : 1 │
│ ARS Route List Number : 2 │
│ Schedule Number : -1 │
│ Number of Digits : 25 │
┌─Consult/Modify: ARS Route──────────────────────────────────────────────────┐
│ ARS Route list : 2 │
│ Route : 1 │
│ Name : ExtGWroute1 │
│ Trunk Group Source + Route │
│ Trunk Group : 15 (also attempted TG 16, detailed below) │
│ Nb.Digits To Be Removed : 0 │
│ Digits To Add : ------------------------------ │
│ Numbering Command Tabl.Id : 3 │
│ VPN Cost Limit : 0 │
│ Protocol Type + Dependant on Bundle Type │
│ NPD identifier : 255 │
│ Route Type + Public │
│ ATM Address Id : -1 │
│ Preempter + False │
│ Quality │
│ [ Add ] [ Remove ] [ Next ] [Previous] │
│ Quality + Speech [plus fax, restricted and unrestricted digital] │
│ Route : 2 │
│ Name : ISDN │
│ Trunk Group : 1 │
│ Numbering Command Tabl.Id : 0 │
│ Quality │
┌─Consult/Modify: Time Based Route List──────────────────────────────────────┐
│ Time Based Route List Id : 1 │
│ Time Based Route │
│ Route Number : 1 [also includes 2 │
│ Waiting Cost Limit : -1 │
│ Stopping Cost Limit : -1 │
┌─Consult/Modify: Numbering Command Table────────────────────────────────────────┐
│ Table Id : 3 │
│ Carrier Reference : 2 │
│ Command : I │
│ Associated SIP gateway : 8 │
┌─Consult/Modify: Network Routing Table─────────────────────────┐
│ Network Number : 4 │
│ Rank of First Digit to be Sent : 1 │
│ Incoming identification prefix : -------- │
│ Protocol Type + ABC_F │
│ Numbering Plan Descriptor Id : 11 │
│ ARS Route list : 0 │
│ Schedule number : -1 │
│ Network call prefix : -------- │
│ Town Name : -------------------- │
│ Send Town Name + False │
│ Associated SIP gateway : -1 │
│ Unable_UTF8 + True │
┌─Consult/Modify: SIP Gateway──────────────────────────────────────────────────────────────┐
│ Subnetwork number : 4 │
│ Trunk Group : 15 │
│ IP Address : 10.10.10.150 │
│ Machin name : oxe │
│ Proxy Port Number : 5060 │
│ SIP Subscribe Min Duration : 1800 │
│ SIP Subscribe Max Duration : 86400 │
│ Session Timer : 1800 │
│ Min Session Timer : 900 │
│ Session Timer Method + RE_INVITE │
│ DNS local domain name : -------------------------------------------------- │
│ DNS type + DNS A │
│ First DNS IP Address : ----------------------------------------------- │
│ Second DNS IP Address : ----------------------------------------------- │
│ SDP in 18x + True │
│ Cac SIP-SIP + False │
│ INFO method for remote extension + False │
│ Dynamic Payload type for dtmf : 97 │
┌─Consult/Modify: Proxy────────────────────────────────────────────────────────────────────┐
│ Initial timeout : 500 │
│ timer T2 : 4000 │
│ Dns Timer overflow : 5000 │
│ Timer TLS : 30 │
│ Recursive search + False │
│ Minimal authentication method + Digest │
│ Authentication realm : asterisk │
│ Only authenticated incoming calls + False │
│ Framework Period : 3 │
│ Framework Nb Message By Period : 25 │
│ Framework Quarantine Period : 1800 │
│ TCP when long messages + True │
│ Retransmission number for INVITE : 3 │
│ Network Number : 11 │
│ Town Name : ExtGWroute1 │
┌─Consult/Modify: External Gateways────────────────────────────────────────────────────────┐
│ Instance : 8 │
│ Gateway Name : ExtGWroute1 │
│ Remote domain : 203.56.203.56 │
│ PCS IP address : ----------------------------------------------- │
│ Port number : 5060 │
│ Transport type + UDP │
│ Belonging domain : 10.10.10.140 │
│ Registration Id : 1234567890 │
│ Registration ID in P_Asserted + False │
│ Registration timer : 10 │
│ Outbound Proxy : 203.56.203.56 │
│ Supervision timer : 0 │
│ Trunk group number : 15 (also attempted TG 16, detailed below) │
│ Pool Number : -1 │
│ Outgoing realm : asterisk │
│ Outgoing username : 1234567890 │
│ Outgoing Password : ********** │
│ Confirm : ********** │
│ Incoming username : -------------------------------------------------- │
│ Incoming Password : ---------- │
│ Confirm : ---------- │
│ RFC 3325 supported by the distant + False │
│ Minimal authentication method + None │
│ Send only trunk group algo + False │
│ To EMS + False │
│ SRTP + RTP only │
│ Routing Application + False │
│ Ignore inactive/black hole + True │
│ Contact with IP address + False │
│ Dynamic Payload type for dtmf : 101 │
│ 100 REL for Outbound Calls + Supported │
│ 100 REL for Incoming Calls + Not Requested │
│ Gateway type + Standard type │
│ Re-Trans No. for REGISTER/OPTIONS : 3 │
│ P-Asserted-ID in Calling Number + False │
│ Trusted P-Asserted-ID header + True │
│ Diversion Info to provide through + History Info │
│ Trusted From header + False │
As SIP Register is required, according to TG0069 a user is required that is a SIP device.
┌─Consult/Modify: Users────────────────────────────────────────────────────────────────────
│ Directory Number : B0010 │
│ Directory name : SIPrego │
│ Directory First Name : -------------------- │
│ Location Node : 1 │
│ Shelf Address : 255 │
│ Board Address : 255 │
│ Equipment Address : 255 │
│ Set Type + SIP device │
│ Set Function + Default │
│ Language Id. : 1 │
│ Associated Set No. : B0010 │
│ Cost Center Id : 255 │
│ Cost Center Name : ---------- │
│ Charging Category + Justified │
│ Public Network Category : 2 │
│ External Forwarding Category : 255 │
│ Tel.Facility Category Id : 0 │
│ Connection Category Id : 0
│ URL UserName : 1234567890 │
│ URL Domain : 10.10.10.140 │
│ SIP Authentication : 1234567890@10.10.10.140 │
│ Password : ********** │
│ External Gateway Number : 8 │
Outbound SIP Trunk Group that is the first route for ARS.. (Ive also tried using an ISDN SIP TG, further details below, same behaviour)
┌─Consult/Modify: Trunk Groups──────────────────────────────────────────────────────┐
│ Trunk Group Id : 15 │
│ Trunk Group Type + T2 │
│ Trunk Group Name : SIP_Local │
│ UTF-8 Trunk Group Name : ------------------------------------------- │
│ Number Compatible With : -1 │
│ Remote Network : 4 │
│ Shared Trunk Group + False │
│ Special Services + Nothing │
│ Node number : 1 │
│ Transcom Trunk Group + False │
│ Auto.reserv.by Attendant + False │
│ Overflow trunk group No. : -1 │
│ Tone on seizure + False │
│ Private Trunk Group + False │
│ Q931 signal variant + ABC-F │
│ SS7 signal variant + No variant │
│ Number Of Digits To Send : 0 │
│ Channel selection type + Quantum │
│ auto.DTMF dialing on outgoing call + NO │
│ T2 Specificity + SIP │
│ Homogenous network for direct RTP + NO │
│ Public Network Category : 31 │
│ DDI transcoding + False │
│ Can support UUS in SETUP + True │
│ Implicit Priority │
│ Activation mode : 0 │
│ Priority Level : 0 │
│ Preempter + NO │
│ Incoming calls Restriction categ. : 10 │
│ Outgoing calls Restriction categ. : 10 │
│ mpt1343 callee number + NO │
│ Overlap dialing + NO │
│ Call diversion in ISDN + NO │
┌─Consult/Modify: Trunk Group────────────────────────────────────────────┐
│ Public Network Ref. : ------ │
│ VG for non-existent No. + YES │
│ Supervised by Routing + NO │
│ VPN Cost Limit for Incom.Calls : 0 │
│ Immediat Trk Listening For VPNCall + YES │
│ VPN TS % : 50 │
│ Csta Monitored + NO │
│ Max.% of trunks out CCD : 0 │
│ Ratio analog.to ISDN tax : ------ │
│ TS Distribution on Accesses + YES │
│ Quality Profile for Voice on IP + Profile #1 │
│ IP compression type + Default │
│ Use of volume in system + YES │
│ Announcement for Dialtone + NO │
│ Announcement for Ringtone + NO │
│ Reroute Anonymous Calls to Entity + NO │
│ Dialling end to end + NO │
│ DTMF end to end signal. + NO │
│ Trunk group used in DISA + NO │
│ DISA Secret Code : ---- │
│ Routing To Executive + NO │
│ Trunk Category Id : 31 │
│ Sending of Progress message + YES │
│ Nb of digits unused (ISDN) : 0 │
│ B Channel Choice + YES │
│ Channels Reserved By Attend. : 0 │
│ Dissuasion For ACD + NO │
│ DTO joining + NO │
│ Enquiry Call On B Channel + NO │
│ Automated Attendant + NO │
│ Calling party Rights category : 0 │
│ TS Overflow + YES │
│ Number To Be Added : -------- │
│ Charge Calling And ADN Creation + YES │
│ LogicalChannel + 1__15 & 17__31 │
│ Use Split Acces + NO │
│ Heterogeneous Remote Network + NO │
│ Barring mode + Not barred │
│ ARS class of service : 31 │
│ External Access Server + NO │
│ Mcdu Trk MonitCsta : -------- │
│ IE External Forward + None │
Inbound ISDN Trunk Group where test call originates, plus is the second route
│ Trunk Group Id : 1 │
│ Trunk Group Name : ISDN10 │
│ Number Compatible With : 0 │
│ Remote Network : 15 │
│ Node number : 1 │
│ Overflow trunk group No. : 2 │
│ Tone on seizure + True │
│ Q931 signal variant + ISDN all countries │
│ auto.DTMF dialing on outgoing call + YES │
│ T2 Specificity + None │
│ Public Network Category : 0 │
│ DDI transcoding + True │
│ Preempter + NO │
│ Overlap dialing + YES │
│ Immediat Trk Listening For VPNCall + NO │
│ VPN TS % : 50 │
│ Trunk Category Id : 19 │
│ Nb of digits unused (ISDN) : 4 │
│ B Channel Choice + NO │
│ Charge Calling And ADN Creation + NO │
┌─Consult/Modify: Trunk Category─────────────────────────────────────────────┐
│ Connection Category Id : 5 │
│ Trunk Type + ISDN │
│ Signalling Type + Not Relevant │
│ Waiting Guide + True │
│ Overflow Timer on No Reply : 300 │
│ Overflow Timer on Waiting : 300 │
│ T2 T0 ABC-F ISDN Trunks │
│ Timer T303 : 40 │
│ Timer T304 : 300 │
│ Timer T310 : 410 │
│ Timer T313 : 40 │
│ Timer T305 : 300 │
│ Timer T308 : 40 │
│ Timer T309 : 900 │
│ Timer T302 : 150 │
│ Timer T386 : 200 │
│ ISDN trunks │
│ Timer T301 : 1800 │
│ Timer T306 : 300 │
│ Timer T316 : 1200 │
│ Timer T317 : 900 │
│ Timer T322 : 40 │
│ Connection Category Id : 0 │
│ Trunk Type + ABC_F │
│ Timer T303 : 100 │
│ Timer T310 : 300 │
│ Timer T313 : 40 │
│ Timer T305 : 40 │
│ Timer T308 : 40 │
│ ABC-F Trunks │
│ Timer T306 : 60 │
│ Timer T314 : 20 │
│ Timer T381 : 1200 │
│ Timer T383 : 1200 │
│ Timer T384 : 300 │
│ Timer T388 : 350 │
│ Timer T389 : 80 │
│ Timer T390 : 1800 │
│ Timer T392 : 10 │
│ Timer T397 : 100 │
┌─Consult/Modify: Connection Category────────────────────────────────────────┐
│ Categories Number : 32 │
│ Connection Rights │
│ Category 0 : 1 │
│ Category 1 : 1 │
│ Category 2 : 1 │
│ Category 3 : 1 │
│ Category 4 : 1 │
│ Category 5 : 1 │
│ Category 6 : 1 │
│ Category 7 : 1 │
│ Category 8 : 1 │
│ Category 9 : 1 │
│ Category 10 : 1 │
│ Category 11 : 1 │
│ Category 12 : 1 │
│ Category 13 : 1 │
│ Category 14 : 1 │
│ Category 15 : 1 │
│ Category 16 : 1 │
│ Category 17 : 1 │
│ Category 18 : 1 │
│ Category 19 : 1 │
│ Category 20 : 1 │
│ Category 21 : 1 │
│ Category 22 : 1 │
│ Category 23 : 1 │
│ Category 24 : 1 │
│ Category 25 : 1 │
│ Category 26 : 1 │
│ Category 27 : 1 │
│ Category 28 : 1 │
│ Category 29 : 1 │
│ Category 30 : 1 │
│ Category 31 : 1 │
│ Category 0 : 1 │
│ Category 1 : 1 │
│ Category 2 : 1 │
│ Category 3 : 1 │
│ Category 4 : 1 │
│ Category 5 : 1 │
│ Category 6 : 1 │
│ Category 7 : 1 │
│ Category 8 : 1 │
│ Category 9 : 1 │
│ Category 10 : 1 │
│ Category 11 : 1 │
│ Category 12 : 1 │
│ Category 13 : 1 │
│ Category 14 : 1 │
│ Category 15 : 1 │
│ Category 16 : 1 │
│ Category 17 : 1 │
│ Category 18 : 1 │
│ Category 19 : 1 │
│ Category 20 : 1 │
│ Category 21 : 1 │
│ Category 22 : 1 │
│ Category 23 : 1 │
│ Category 24 : 1 │
│ Category 25 : 1 │
│ Category 26 : 1 │
│ Category 27 : 1 │
│ Category 28 : 1 │
│ Category 29 : 1 │
│ Category 30 : 1 │
│ Category 31 : 1 │
Alternate outbound SIP Trunk Group (ISDN all countries) that has also been tested as the first route for ARS..
│ Trunk Group Id : 16 │
│ Trunk Group Name : SIP_Remote │
│ Node number : 1 │
│ Preempter + NO │
│ Entity Number : 0 │
│ VPN TS % : 50 │
SIP timer T2 8000
TRUNK COS31
T306 120
T310 120
T314 120
| PIN Code = 0 |
| vpnCostLimit = 0
| idx_atm = -1
| ==> dialing_table 3
| command : I
| network : NETWORK2
| SIP gateway : 8
| Route Type = Public
| NPD Id = 255
| Preempter = 0
| vpnCostLimit = 0
| idx_atm = -1
| Route Type = Public
| NPD Id = 255
| Preempter = 0
ARS privilege │
│ Night : 31 │
│ Day : 31 │
│ Mode 1 : 31 │
│ Mode 2 : 31 │
│ VPN Cost Limit │
│ Night : 31 │
│ Day : 31 │
│ Mode 1 : 31 │
│ Mode 2 : 31
│ Number : 0 │
│ Area Number : 1 │
│ Route : 1 │
│ Quality │
│ Route : 2 │
│ Name : ISDN │
│ Trunk Group : 1 │
│ Quality │
│ Table Id : 3 │
│ Command : I │
│ timer T2 : 4000 │
│ Timer TLS : 30 │
│ Instance : 8 │
│ To EMS + False │
│ SRTP + RTP only │
│ Node number : 1 │
│ Preempter + NO │
│ VPN TS % : 50 │
│ Node number : 1 │
│ Preempter + NO │
│ VPN TS % : 50 │
│ Timer T303 : 40 │
│ Timer T313 : 40 │
│ Timer T308 : 40 │
│ ISDN trunks │
│ Timer T322 : 40 │
│ Timer T313 : 40 │
│ Timer T305 : 40 │
│ Timer T308 : 40 │
│ ABC-F Trunks │
│ Timer T306 : 60 │
│ Timer T314 : 20 │
│ Timer T389 : 80 │
│ Timer T392 : 10 │
│ Category 0 : 1 │
│ Category 1 : 1 │
│ Category 2 : 1 │
│ Category 3 : 1 │
│ Category 4 : 1 │
│ Category 5 : 1 │
│ Category 6 : 1 │
│ Category 7 : 1 │
│ Category 8 : 1 │
│ Category 9 : 1 │
│ Category 10 : 1 │
│ Category 11 : 1 │
│ Category 12 : 1 │
│ Category 13 : 1 │
│ Category 14 : 1 │
│ Category 15 : 1 │
│ Category 16 : 1 │
│ Category 17 : 1 │
│ Category 18 : 1 │
│ Category 19 : 1 │
│ Category 20 : 1 │
│ Category 21 : 1 │
│ Category 22 : 1 │
│ Category 23 : 1 │
│ Category 24 : 1 │
│ Category 25 : 1 │
│ Category 26 : 1 │
│ Category 27 : 1 │
│ Category 28 : 1 │
│ Category 29 : 1 │
│ Category 30 : 1 │
│ Category 31 : 1 │
│ Category 0 : 1 │
│ Category 1 : 1 │
│ Category 2 : 1 │
│ Category 3 : 1 │
│ Category 4 : 1 │
│ Category 5 : 1 │
│ Category 6 : 1 │
│ Category 7 : 1 │
│ Category 8 : 1 │
│ Category 9 : 1 │
│ Category 10 : 1 │
│ Category 11 : 1 │
│ Category 12 : 1 │
│ Category 13 : 1 │
│ Category 14 : 1 │
│ Category 15 : 1 │
│ Category 16 : 1 │
│ Category 17 : 1 │
│ Category 18 : 1 │
│ Category 19 : 1 │
│ Category 20 : 1 │
│ Category 21 : 1 │
│ Category 22 : 1 │
│ Category 23 : 1 │
│ Category 24 : 1 │
│ Category 25 : 1 │
│ Category 26 : 1 │
│ Category 27 : 1 │
│ Category 28 : 1 │
│ Category 29 : 1 │
│ Category 30 : 1 │
│ Category 31 : 1 │
│ Node number : 1 │
│ Preempter + NO │
│ VPN TS % : 50 │
- tot3nkopf
Re: ARS issue - 1st Route SIP TG, 2nd ISDN
SIP to CH should be the way. Which SIP message do you receive when line is unavailable? There are also new options for detecting out of service SIP ext gw in new releases if this is the case. So main question is: unavailability is of the gw or is on SIP messages?
Interestingly, nothing appears in the SIP (traced) logs when I test the inbound call. I can't see the OXE attempt to contact the gateway.
Ill login, break it, and run another trace in a few hours however that is the tested outcome until now.. nothing!
Yet in its current state (its still using ARS but the SIP TG is active) the calls work perfectly (though there does seem to be registration time outs every so often).
I was expecting to see some kind of SIP message in the the SIP motor such as 501, 502, 503, 504, 600, 604, 480 or something like that when I intentionally add a bad static route..
When I take the SIP external gateway of of service (i.e. set the TG to -1) I would just expect the OXE to see that route 1 is out of service and use route 2, but it even fails to do this.
Very confusing..
Very confusing..
- Konstantinos.E
hi
just an idea... for how long the TG shown as active?trkstat what is the result? is always in service? if after some period check quality of service...sip keep alive messages timer?
Alca_holic
Hi people,
My bane is similar a little... My first problem: we have a small company and an OmniPCX PBX.
We have a SIP trunk (6 channels) and an ISDN trunk group with four accesses (in total 8 channels). An outbound call via SIP trunk is far more cheaper than via ISDN - so we would like to send these calls via VoIP primarily.
BUT: we have 13 DDI numbers which are able to come into our PBX via that SIP trunk only. I think I have to reserve a few channels for them.
Can I limit number of outbound calls via SIP? E.g. we create a limit: max. 4 outbound calls simultaneously. If four outbound calls are in progress via SIP, the next outbound call will run via ISDN. So in the worst case remains two channels for our VoIP numbers' inbound calls.
Is this restriction possible?
Yeh, and when SIP is unavaliable (e.g. problem with our internet connection) all of outbound calls have to run via the ISDN trunk group - similar to jazzepat's problem.
My second problem: I am absolutely NOT an expert in PBX programming. So anybody knows a good solution for me please write ALL step by step...
Thanks in advance,
sagyuri
Thanks in advance,
sagyuri
Do you have OXE or OXO system?sagyuri wrote:Hi people,
This topic refers to OXE. As you said yo have a small company maybe you are talking about OXO.
Hi L_lefante,
Maybe it is OXO; main cabinet: OMNI PCX L (2G).
This is a rack box with 8+1 card slot. If sw versions are important I can look for them.
Ok. In case of OXO you can limit outgoing calls by modifying the amount of channels available for VoIP. This parameter you will find it in Voice Over IP > VoIP: Parameters > General.
This restricts the amount of total communications, so you should select a number according with the traffic you want to have, both incoming and outgoing.
Secondly, for outgoing calls you have to manage ARS overflow, so in case of busy trunk group calls will overflow to ISDN trunk group.
Regards.
Regards.
- cavagnaro
Same HW can be used on both basically.sagyuri wrote:Hi L_lefante,
What software you use to control your PBX?
Hi cavagnaro,
I use the OmniPCX Office management console 9.0.18.1 program. I see these in OMC / [company name] / System Miscellaneous / Software Versions menu:
IBS: 100/003.016
IBS NG: 100/049.003
IBS PWT: 200/001.024
Multi Reflex: 100/001.006
I hope these are useful...
IBS: 100/003.016
IBS NG: 100/049.003
