incorrect local & distand ID's
Re: IPView 2.0 Released
PLs : Check the file , When I useing "H323 IP VPN " or "SIP Trunk call " Log ,The "Local ID" and "Distant ID " are
incorrect !!
Thank You ||
incorrect !!
Thank You ||
Dear wuchihhung,Mr_Sven wrote:what file?
I need examples. Ticket Files! Screenshots.
Sven
I'm Jeffrey. I already got the screenshots.
Dear Sven,
Here is the screenshot.
http://www.wretch.cc/album/show.php?i=J ... 073831&p=0
The "Local ID" and "Distant ID " are incorrect !!
But, I don't know how to attach the ticket file in here.
Can you give me your e-mail address??
I can attach the ticket file through e-mail.
Thanks for your help, this is a very good tool.
Jeffrey
Send you a PM, please attach screenshot and ticket to the E-Mail, because the screenshot is very small.
PS: look in the about frame, there is also my e-mail address
I've decoded the ticket, I can't see any error.
It is a problem of the PBX, because the tickets and the analyzer are ok,
What do you expected?
This is a bit code structure of the ticket.
ID Length Value
0A 001E 040209090900000000000000000000000000000000000000000000000000
10 30 42999
0B 001E 0806010A0504040400000000000000000000000000000000000000000000
11 30 84105444
Dear Mr_Sven,Mr_Sven wrote:I've decoded the ticket, I can't see any error.
This is a bit code structure of the ticket.Code: Select all
ID Length Value 0A 001E 040209090900000000000000000000000000000000000000000000000000 10 30 42999 0B 001E 0806010A0504040400000000000000000000000000000000000000000000 11 30 84105444
I think that the settings about VOIP in our OXE maybe not right or incompletely.
We'll keep to test and try to find out the root cause of this problem.
Anyway, thanks for your kindly reply. IPView is really a useful tool for us.
Jeffrey
Re: incorrect local & distand ID's
I have a miss information from the ticket view in order for watch the CoS an vlan ID information for vlan Id indicates the value 4095 and for CoS it indicates 0.
And for DSCP is 184, but when i use the ethereal it looks ok with vlan id=5 and presedence 46.
Is there a bug in the ticket view ????
Because that information is just with the Web Softphone,cause with the IP_Phones s ok.
- cavagnaro
Please post some screenshots to get a more clear idea.
Ya pues!
Ya pues!
VLAN id:
R&D: For the moment , this field is used only in some specific IPPHone binaires according to TS needs
Defaultvalue 4095.
Defaultvalue 4095.
