7750 Ring protocol issue.
yukunchang
Post by yukunchang »
Dear all
Composed ring network. Use 7750-SR Router.
Question.
How to active View Ring Topolgy on SAM5620 ??
I need your Help..
Thank you..
config is Ring protocol on 7750-SR :
A:C1>config>eth-ring# info
revert-time 60
path a 2/1/6 raps-tag 2000
eth-cfm
mep 1 domain 1 association 5
ccm-enable
control-mep
no shutdown
exit
exit
no shutdown
exit
path b 2/1/5 raps-tag 2000
eth-cfm
mep 11 domain 1 association 1
ccm-enable
control-mep
no shutdown
exit
exit
no shutdown
exit
no shutdown
DoobieHowserMD
Re: 7750 Ring protocol issue.
Post by DoobieHowserMD »
If you are looking for APS Bundles/Groups then that is viewable in the Navigation Tree, drop-down at top set for Equipment and then expand your 7750 out until you get to Shelf 1. When you expand that out you will see APS Bundles or Groups.
If you are looking for Ring Groups then in the same Navigation Tree window you will need to change the drop-down at top to Ring Group and then you should be able to see more by expanding those items out.
Return to “5620 SAM”
