Ladies and Gentlemen,
could you please to assist me?
Our Hi-Tech customer installed OXO R9 with public SIP trunk. He would like to connect Skype to his OXO now.
He send me link to the Skype Community, where Victor S., Skype Enterprise Support, wrote to Mr. George Christopoulos that "We have other users using the OmniPCX without any problems" in 21-09-2011.
I found that Alcatel – Lucent is not Skype Connect certified SIP-enabled PBX vendor too.
Could you please share your latest field experience concerning the connection between OXO and Skype Connect?
With best wishes
krustins
Skype Connect integration with OXO R9.0
- giovanni.attolini
Re: Skype Connect integration with OXO R9.0
I've tried to use Skype Connect with OXO but I didn't have success. The problem is that OXO doesn't accept the Outbound Proxy like a name, only like na IP address, and to use Skype Connect you need to enter a server name and not it IP address. I don't know if Skype changed something in his system, maybe today is working.
Giovanni A. Attolini
Hi All,
I'm working on the same problem with Skype Connect OXO R9.1. Any resolution
Gio ,Try with Crtl C + Crtl V ! Lol (Notepad)
- giovanni.attolini
Not yet...
A lot of this problem is found because such SIP providers aren't tested in interworking report by ALU, so depending on the SIP system, it doesn't work. I had a situation that giovanni.attolini knows about a SIP provider called Tellfree in Brazil, it didn't work with OXO. I asked ALU about some technical support, they sad: Tellfree is not a SIP provider supported/approved.
Regarding the approved SIP provider in Brazil, There is no one approved by ALU for OXO.
Best regards.
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
ACFE OXE R12
ACFE OXO C R3
- giovanni.attolini
Yes, Enio is correct. ALU could create a checklist for guide us (partners) to make the tests with SIP providers and change the list of supported providers.
