Hi Guys
Im newbie here in Oxo, anyone can help me and guide me how to configure/setup PIN Codes before user can make IDD calls?
E.g Dial 9 followed by 001 then PIN CODE lastly the International Number.
Thanks in advance!!!!
Pin Code for IDD Calls in OXO
- giovanni.attolini
Re: Pin Code for IDD Calls in OXO
Are you talking about the speed dial function?
Speed dial is a table of codes and numbers, when the user access the code it will call to the corresponding number.
Giovanni A. Attolini
- tot3nkopf
Traffic sharing and barring-->account code table
Hi Giovanni
Not speed dial. Im referring to pin code or authorization code wherein each admin users have their own 4 digit pin code that they are going to use to call IDD.
Example:
User A has 5678 pin code. Then if he need to call idd, he need to use this code.
Example: dial 9 + 001 (telco idd access code) + 5678 (User's pin code) + oversea number.
Liksewise for User B, which has 9543 pincode, he will call idd by this way:
dial 9 + 001 (telco idd access code) + 9543 (User's pin code) + oversea number.
Kindly guide me if u know how to setup this thing.
Example:
Hi tot3nkopf
Appreciate if you can give more detailed steps.
- tot3nkopf
You can find this in the system documentation.oloap_09 wrote:Hi tot3nkopf
