Break IN between OXO and Cisco
polypan
Post by polypan »
Hi to everyone!!!
My oxo systems connected with cisco route (CME) via digital trunk. I have internal communication between OXO and Cisco and I would like to distribute my public incomming calls from oxo to cisco router. For example my ISDN DID 361011 -> 5000 internal Number of cisco. The issue can be solved with virtual extension and immediate forward to 5000 but i would like to know if i could route the incomming call via public numbering plan.
what is the scope of DID modification table?"
Thanks in advance
rui.costa
Re: Break IN between OXO and Cisco
Post by rui.costa »
The use of “Collective Speed Dial” or “Virtual Extension” is the easiest way.
It is possible to send directly from “Public Numbering Plan” to ARS to convert the public number into the other side private number
Example:
The DDI number is 214164506 but the public operator sends only the last 3 digits (506)
Start=506, End=506, Base=ARS, NMT=Keep, Priv=Yes
“Installation Numbers”
Installation Number =214164
“ARS”
Network=Priv, Pefix=214164506, Substitute=5000 (the other side private number),….
polypan
Post by polypan »
Regarding your reply i choose the "collective speed dial"
RUI.kosta thanks for your answer.
Return to “Configuration”
