NPD numeber Restriction
Hi Guys
first thank you in advance for any replay
i was surprised when i try to create a new external NPD , the oxe returns" npd already in use".
the real managed NPDs are from 0 TO 34, so NPD N° 35 or above can't be crated
Looknpd n all gives from NPD N°35 TO 49 unused
is it a license problem ? how to increase the number of manageable NPD's ?
Re: NPD numeber Restriction
sorry
system release 7.1
Is this a networked system?
Hi Tot3n and t
yes of course, it is a networked system with 8 other systems in same ABC-F net/subnet
all of them are in same release 7.1
murraya
Post by murraya »
hi, what I think Tot is getting too is to check other nodes in case that NPD is inuse elsewhere.
Best Regards
Murray
ACSE 10.0 corporate
ACSE 6.x IPT data
When you create NEW NPD (after 32) - you create NPD with ANOTHER name?
hi Murray and Vad
@Murraya i checked in other nodes and i see same thing in Npd there 35 npds from 0 to 34
@Vad last npd witch i have created there's more than 3 years was npd numebr 34 and name assigned by pcx is Public_operator
hoho! very good dear guru Vad! excellent !i have change the name from default Public_Operator to another name before confirmation and it was successfully created .
thanks very much Dear Gurus you are very help full what we can do without you ?
Return to “Translator”
