I am having this problem in a hotel set, that there is language code like UK coming at the end of the guest name, when anyone calls that extension, after check - in. Even when the set is checked out , this code appears on the display when someone calls the extension.
I do not want this code to appear, because this shortens the display , and the room number is not displayed.
How can i do this.
Mustafa
Language Code on Hotel set
Re: Language Code on Hotel set
got any solution for the isssue..as i am also having the same problem and need to remove that language code from the GUEST name.
Please assist.
Sandeep
Please assist.
Sandeep
Dear All,
Did you solve this issue?, as i am also having the same problem.
Not yet
Any suggestions from the experts????
Sandeep
Sandeep
- mustafa.ahmad
Go to mgr / applications / hotel /
review/modify
go to language parameter and make it false....
review/modify
Its "FALSE"mustafa.ahmad wrote:Go to mgr / applications / hotel /
review/modify
But still shows the Language TEST UK
Sandeep
- mustafa.ahmad
yaar Sandeep , the language code will always cum,if the set is defined as a room set in the system, as it is a complimentary part from the hotel application in the alcatel PAX....
the parameter that i hd givn u is if u do not want to specify the language at the time of check-in... if it is true ,, the system asks for language at the time of check-in...
Hi Mustafa
"Language" was already set to FALSE but still language code appeared on Attendant console.
regards,
Ray
regards,
Ray
