I spent all afternoon, trying to figure why this board doesn´t start. INTIPA with CPU6
The story.
Power fails
I Start the PBX, and everything start ok, internal and external communications, except from this site to others.
I can ping the INTIP.
I connect to the INTIP console and it shows an error,
000001A-00000B85: ConfigIP : Startup of Ethernet Link succeed
0000001B-00000B85: ConfigIP : IP Address : 172.100. 1. 9
0000001C-00000B85: ConfigIP : IP Subnet Mask : 255.255.255. 0
0000001D-00000B85: ConfigIP : IP Default Router : 172.100. 1. 1
0000001E-00000B86: ConfigIP : Query Default Router 172.100. 1. 1 using ICMP EC
HO REQUEST .
0000001F-00000B86: ConfigIP : Default Router alive
00000020-00000B86: LANPBX : Try to download the file 'lanpbx.cfg' from server 60
.116.133.1
00000021-00001C02: ConfigIP : Ethernet check success
00000022-000031AB: MngtC1cpl : WAIT FOR C1 CLOCK
Reset: Huge loss of clock (ano 00000101 save 00000001) <0>
Flushing Black Memory Hole ...
Restarting Board...
On the mgr I have
gethostbyname: Connection refused
ExitBTlink
I try lanpbxbuild and I get
Wrong configuration of the CPU there is no localhost !
See administration tool : netadmin
I go to the netadmin to see hosts and I get
Host name or address (default is all):
class all real,guest,anonymous *
email root@localhost
--More--(93%)
loginfails 5
readme README* login
readme README* cwd=*
message /welcome.msg login
message .message cwd=*
compress yes all
tar yes all
chmod no guest,anonymous
delete no guest,anonymous
overwrite no guest,anonymous
rename no guest,anonymous
log transfers anonymous,real inbound,outbound
shutdown /etc/shutmsg
--More--(88%)gethostbyname: Connection refused
ExitBTlink
passwd-check rfc822 warn
passive ports 0.0.0.0/0 10000 10499
I saw some posts and I do not have the file tftp on etc/xinetd.d
Who can I copy this file from my laptop to the oxe, I aldready try why a tftp app (filezila) but I Get an error.
Any sugestion???
Thanks in advanced
