CLI on analog trunk lines
orangebusiness
Post by orangebusiness »
how to activate cli on analog trunk lines?
system is having clidsp daughter board on trunk card.
Re: CLI on analog trunk lines
external lines/ list of access - for access (in details) - check item CLIP.
orangebusiness
done this,not working
mujib.alu
Post by mujib.alu »
HI,
1.Check from provider CLIP on FSK/DTMF, If DTMF convert to FSK using FSK converter also confirm the cli using ID phones.
2. check DSP Parameter for NDDI board, System > Tone detector Parameters > DSP Parameters
3.Check CLIP Signal on Shelf > Board (V23 short ring or Long)
4. restart the NDDI board
5. Consult the Docx..
orangebusiness
this is OXO system,sir
But CLI info present? If you connect analog set to analog line (without PBX) - CLI info present on set display?
orangebusiness
vad wrote:But CLI info present? If you connect analog set to analog line (without PBX) - CLI info present on set display?
cli is coming without PBX perfectly
mujib.alu
Post by mujib.alu »
yes,
It is FSK or DTMF signal..?
orangebusiness
mujib.alu wrote:yes,
in india this is DTMF signalling
mujib.alu
Post by mujib.alu »
So you are using FSk converters..? If FSK convetret used did you check the CLI(FSK support Thomsan/Alcatel ) analog phones after the FSK converter.
Return to “Configuration”
