I have analog external lines, and in the pri trunk i have 20 external lines. I want 4 secondary trunk, and each secondary trunk has 1 external line. Now i want to configure 4 subscriber lines to use the secondary trunks for external line.
1. subscriber -> use only secondary trunk1
2. subscriber -> use only secondary trunk2
3. subscriber -> use only secondary trunk3
4. subscriber -> use only secondary trunk4
other subscriber lines will use the pri trunk.
Please help!
Thank you!
pri and secondary trunks
Re: pri and secondary trunks
The most easy way:
entity 1 - manage TG ID 1
entity 2 - manage TG ID 2
entity 3 - manage TG ID 3
entity 4 - manage TG ID 4
entity 5 - manage TG ID 5 (PRI)
Outgoing call via ARS prefix.
All numbers via ARS route 0 - 1st route - TG source=Entity. TG number=-1.
All user from entity 1 will use TG1.
Another solution:
in TG 1 - overflow TG=2
in TG 2 - overflow TG=3
in TG 3 - overflow TG=4
in TG 4 - overflow TG=5 (PRI)
Outgoing call via TG 1 seizure prefix.
You can manage (f.e.)
Access COS 1/ TG access COS - allow only TG1
Access COS 2/ TG access COS - allow only TG2
Access COS 3/ TG access COS - allow only TG3
All users with public Network COS 3 will use TG3.
Another solution:
- Konstantinos.E
hi
Vad told the correct way for OXE configuration.For OXO you have to manage the link categories in the subsribers and trunk groups and ARS table.In documentation witch is available in this forum is well writen.
Alca_holic
Upps.
ARS, TG list and sharing.
