OXO-4300
Konstantinos.E
OXO-4300
Post by Konstantinos.E »
i have interconected a 4300 with OXO r7.1 with analog trunking.the T2 line is located to the OXO and through abriviated numbering and virtual users i managed the system to work.
after a few days of working i realized that sometimes i have a problem with backward release.i have tryed to evrything in the trunk group management but seems the OXO dont understand the release.So i desided to manage the debug label autoreset everyday at 12 oclock so all lines will be released if there is any stacked.
Everything seems to work ok but after some period the MLAA doesnt come up but only with cold reset.The system doesnt see the hard drive.I think this is because of too many resets.
is there away to reset only the T2 line or APA automaticly with out rebooting the system? So to avoid everyday reseting?
thanks.
Alca_holic
Re: OXO-4300
External lines-->line-->out of service tick?
Konstantinos.E
Re: OXO-4300
hi
thanks for the reply tot3nkopf!
in t2 i think you cant do this.only in APA.The problem is that everyday i have to log on in the system and make this tick.
I am asking if there is any debug label that resets the trunks or slot to avoid the reset.
thanks!
Alca_holic
Re: OXO-4300
None that I know of. You can check noteworthy addresses, but not all are documented.
Return to “Configuration”
