AlcatelUnleashed migrated to a new server. Expect some latency for 72hrs
4760 licens issue
phustc
4760 licens issue
Post by phustc »
I have a problem, when I start 4760 client, "Expired license" is displayed in screen,
If I press next link, "Unable to connect to server" is displayed in screen.
please give me some advices.
Thanks.
oldboy
Re: 4760 licens issue
Post by oldboy »
Are you using a temp licence? if so then your 4760 will not work until you have a proper licence
phustc
Post by phustc »
The issue does not exist.
I change the system time, eg: 2011-1-20 change to 2010-1-23.
Reboot the system and login into the system, the 4760 licesne issue cannot exist.
Thanks.
oldboy
Post by oldboy »
Yep so you are using a temp licence or a timed one to be more exact that ALU will supply for short demo and the like. But if you are using this licence and reports all dates will be wrong, better to get right licence.
Return to “4760”
