Block internal traffic
fernan05
Post by fernan05 »
hi
Can i block internal traffic?
for example: the internal subscriber 100 can not call to internal 110; or block traffic between groups.
thanks
Konstantinos.E
Post by Konstantinos.E »
traffic sharring and barring ander omc. make a new table and with prefixe 1 forbidden adn then go to the user details under restr/barring put the cos restriction link the table that you created...
enio.eltz
Post by enio.eltz »
There isn't block for internal calls in OXO like OXE has with connecting categories.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
enio.eltz
Post by enio.eltz »
I forgot.
Traffic sharing and barring is only used for external calls.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
Konstantinos.E
yes enio.eltz has right...i was confused...
fernan05
Post by fernan05 »
So, it is not possible?
Thank you very much for your answers
enio.eltz
Post by enio.eltz »
Yes, it isn't possible.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
etc
Post by etc »
You can use selective forwarding feature for disabling/enabling some numbers calling some internal numbers.
Return to “Configuration”
