Problem Seizing ISDN T1 Trunk Group
dcwilliams
Post by dcwilliams »
I am not able to dial out to the public network. I dial "9" and then the external number. When I dial "9" I get dial tone and then when I key in the net number I get a error message. I have checked the numbering paln and ARS but it looks OK to me. Any ideas?
enio.eltz
Post by enio.eltz »
Hi dcwilliams
Who sends the message? OXO? Carrier? Are you receiving error tone? You can have a problem with call barring. Is the board as T1 at hardware and limits --> cabintes?
Best regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
dcwilliams
I see this messge on the user handset. I do see the board in hardware limits.
enio.eltz
Post by enio.eltz »
Is it a voice guide ( a spoke message )?
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
dcwilliams
No. This is the message on the LCD display of the phone I am dialling from. External calls are coming into the OXO fine. Users are not able to make calls to the public network.
enio.eltz
Post by enio.eltz »
Ok, it seems a barring problem or the oxo isn't sending the correct A number. Can you send me a database to enio@uniteltelecom.com?
Best regards
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
dcwilliams
OK. Will do.
Dwyer.
dcwilliams
I have sent you database.
dcwilliams
I got it working. For some reason I had to delete the autoamtic routing prefix for the public trunk and put it back in. I guess there must have been some corruption in the database. Thanks for your help.
Return to “Configuration”
