I want incoming trunk to ring "all" phones on a 4200c...
danny
Post by danny »
I added all extension to one group and tried to let the incoming trunk ring this group but only the 'main' extension will ring when receiving a call :confused:. If I call the group all extensions will ring without any problem.
Where can I find this ? Any help appreciated !
steve
Post by steve »
I think you have to change the type of the hunting group from sequential to parallel.
jan
Post by jan »
Hi Danny,
You have to dyn route attendant group to huntgroup.Or you can set it up in the numbering plan that it rings straight to hunt group.
Krusty65
Post by Krusty65 »
It has been a while but you should be able on UA sets to program a general monitoring key and on Z's tick the option for general monitoring in the virtual keys, this should make all sets ring on an i/c call
telecom
incoming trunk ring all the memebers of a hintinggroup
Post by telecom »
in my example is huntinggroup nr 501
Go to numbering
public numbering plan
fill in huntinggroup
start = group number = 501
end= groupnumber = 501
base= groupnumer = 501
eg 501 501 501
than go to your trunkslist
select trunk
call.dist
fill in your huntinggroepnr. (eg 501)
you can do the same with subscibers
and alltraffic of that trunk will go to your huntinggroep
dear regards
Ruud
danny
Post by danny »
Thank you all for the help...! For the moment I did find General Ring (? not sure if this is the name of the General... ) which will do the trick for the moment but will do some more programming next week !
Danny
Return to “42xx Systems”
