Ok, OMC means you have OXO.
L_lefante suggestions should work
ARS issue - 1st Route SIP TG, 2nd ISDN
- cavagnaro
Re: ARS issue - 1st Route SIP TG, 2nd ISDN
I would like to know if somebody get to solve this in OXE.
I have an ARS with mini-SIP TG as the first route and then an ISDN as the second.
1. The mini-SIP TG is connected to a GW Mobile with just 3 sim cards (chips), so, the 4 sip channel is always free and never will get full of occupation to cause the diversion to the next ARS route.
2. I've forced the MAX ABCF-IP and SIP connections to 3 in the mini-sip TG. But definitely the diversion to the second ARS Route doesnt work, I get the "No authorizated" message in the phone for the 4 call.
What is the rigth way to force to 3 channels a mini-SIP TG?
What could I do cause the diversion for the 4th call?
E
E
- cavagnaro
You MG should return a Busy message.
- tot3nkopf
Try to do a SIP to CH mapping with the message that you receive in SIP when channels are all occupied. Map it to smth like no circuit. See how it goes.
User Busy will not make OXE select next route. If the user is busy it does not make any sense to select another path.
In order to make OXE select the next ARS route, GW should return No circuit/channel available, Swicthing equipmente congestion, ...
- tot3nkopf
From what I remember with mapping you can do SIP to CH --> busy to no circuit (if no other way on gw.)
If you do that, then if the user is busy you will have two outgoing calls, one via GW and another via ISDN, and the final result, is user busy. This does not make sense.
- tot3nkopf
Depends on how the gw signals the two cases: user on far end busy or channel unavailability. When both are signaled as busy I am with you. Smth has to be done on gw to dissociate between the two.
may be it can help
when all sim are used the next step is null port with isdn code no circuit you can remove the sim from gsmgateway routing rule and apply the isdn code
