OmniPCX Recording - Silent monitoring not working
krzysioD
Re: OmniPCX Recording - Silent monitoring not working
Post by krzysioD »
I think you will need some license for Omnipcx record too. And some hardware if not only ip-recording...
poposami
Post by poposami »
I am looking for OPS to try the RECORD application.
My OPS has lock 130 set to 1 .So It does not work with pcx record.
Could you provide yours (by email)
astuto00
Post by astuto00 »
jacob87 Hello, I am also working with the OmniPCX Record but it does not work the Silent Monitor Might indicate where I changed the compression type on the PBX OXE? ...?
jpalbinet
Post by jpalbinet »
On the OmniPCX Record server go to Program files\alcatel lucent\omnipcxrecord suite\Server
Find the configuration file named “OXERecordServer.exe.config”
open it in notepad
Change the value of CSTA_ESCREGREQ to 11 By default it is set to 234 which is Omnipcx record license.
Restart the recorder
Return to “OmniPCX Record”
