Cannot connect to PowerCpu using OMC Serial
wallacezammit
Re: Cannot connect to PowerCpu using OMC Serial
Post by wallacezammit »
I use a built-in com port and still without success.
I tried with different pc's and with different oxo powercpu's and never managed to connect serially to them.
anbani
Post by anbani »
Hi all,
Today, i received OXO R8.0 and PowerCPU. I tried to login with serial but it's fail. I don't understand this problem. (My console is right and good work)....
Any idea..!!!
anbani
Post by anbani »
Hi all,
I tried to connect V24, 115000 bit on the Hyper Terminal and success, but on the OMC fail....I tried on the Win7,XP,2003
Any new..!!!
wallacezammit
Yes with hyperterminal it works but with omc it fails!
still dont have any idea of whats going on!
I will also open a case with alcatel on this issue.
OXO-Man
Post by OXO-Man »
Hi all,
Ive got this problem too and opened an eSR.
The actual status is: treatment in progress
It seems that the processor on the PowerCPU is too fast so that there will be timing problems......
Best regards
OXO-Man
ACSE OXO R8.0
ACSR OXO
ACSR Eye-Box
ACSE OXE R9.1
.. and a lot of more...!
hunggundam
Post by hunggundam »
hi all
i use "usb to serial com port" to connect R.8 PowerCPU. it is fault.
but i use same cable and computer to connect R.7. it is sucess.
why? anybody have idea?
enio.eltz
Post by enio.eltz »
There is a difference between pwCPU and the old CPUs. As we can see in the manuals, in the pins of the pwCPU there's no description about pin #2 (DSR). For the oldest there is, DSR that we connect at the DB9 pin #4 (DTR).
I don't think ALU made a mistake about the pwCPU, but there can be a problem with OMC.
Regards.
Enio Eltz Filho
ACFE OXE R12
ACFE OXO C R3
hunggundam
thanks enio
would you tell me correct pin assignment (RJ45 to DB9) for R8 PowerCPU?
anybody know that
hunggundam
enio.eltz wrote:Hi
Regards.
thanks enio
anybody know that
OXE_4400
Post by OXE_4400 »
TC1541: OMC Local V24 connection issue on some PowerCPU
Problem description
Connectivity issues have been reported with OMC local V24 connection on some PowerCPU's.
When the problem occurs, following error message is displayed on OMC : " 777. The connection attempt
failed because the modem or (other connecting device) on the remote computer is out of order…"
This issue is due to a DTR signal random level on some PowerCPU's.
2 Solution
The issue can be fixed with a modification of the V24 cable described in the Technical Documentation
a) Standard cable (technical documentation)
RJ45 SUB D9 on PC
1 7 RTS
3 3 TXD
5 5 GND
6 2 RXD
8 8 CTS
2 4 DTR
7 6 DSR
b) Modified cable
Disconnect the DTR and DSR signals on the SUB-D9 connector and loop pin 4 & 6 :
RJ45 SUB-D9 on PC
1 7 RTS
3 3 TXD
5 5 GND
6 2 RXD
8 8 CTS
2 ∫∫ 4 DTR
7 ∫∫ 6 DSR
Note : the modified cable is compatible with all CPUs (CPU-1 to CPU-4 and CPUe-1/2) and all
PowerCPU's.
3 PowerCPU enhancement
A hardware modification is applied on the PowerCPU's with reference : 3EH73084 AKJD 08.
These boards were delivered from the factory since the following dates :
- August 10th 2011 for PowerCPU with serial number ZSR 011 222xxxx (*)
- August 29th 2011 for PowerCPU with serial number ACC 011 241xxxx (*)
(*) ABC 011 222 xxxx
Year 2011 Day 222 (08/10)
Return to “Configuration”
