sip trunking with avaya ip office
kapiltci
Re: sip trunking with avaya ip office
Post by kapiltci »
thanks, in oxo we are using qos 10100000 IP PRECEDENCE 5
PLEASE TELL ME WHAT BANDWIDTH IS REQUIRED FOR 4 VOIP CHANNEL in oxo?
kapiltci
Post by kapiltci »
we are using QOS in oxo 10100000 IP PRECENDENCE 5
please tell me what bandwidth is required for 4 voip channel in oxo?
jas13
Re:
Post by jas13 »
tot3nkopf wrote:Some observations:
First of all the gateway was down the moment you took this database. can you ping Avaya from OXO subnet?
Second: in gw parameters: you should enter domain and realm as IP of Avaya
Third: in SIP public numbering remove + (maybe Avaya doesn't like it) and use at calling/called regionalk undefined, unknown, DDI; otherwise the numbers you send/you call will look like +00911xx/+00913xx (for canonical international for example).
Hi, I have done the configuration as above, and not able to make calls to AVAYA extensions (showing release immediately when numbers are dialled), but able to receive calls from AVAYA extensions and able to talk properly.
What may be the reason.
Logs
Return to “Configuration”
